1998 Plymouth Voyager distributor
JDAYTON26
Electrical problem
1998 Plymouth Voyager Automatic
what could cause it from getiing any sparks from the distributor
Nov 8, 2008 at 4:09 AM
DAVE H
  • 13,383 POSTS
there are 101 reasons you may not be getting a spark .. crank sensor/coil etc. etc even the immoboliser cuts the spark .. is your MIL on ?? if you have a light flashing/constantly on, on the dash display then you have a fault code showing ..you willl have to have the PCM read to get the code which will tell you where the fault lies ?
Nov 11, 2008 at 8:18 AM
