1998 Plymouth Voyager Cooling Fans
152,000 MILES • 6 CYL • FWD • AUTOMATIC
CRISDAPOET
My cooling fans will not shut off when I turn key off. I have to disconnect the battery or remove the radiator fan 40amp fuse.
May 28, 2008 at 10:27 PM
  • 75,988 POSTS
Check the fan relay could be sticking or the engine temperature gauge switch/coolant temperature sensor-
May 28, 2008 at 10:40 PM
