About every 2 days coolant from overflow empties out, checked radiator and it would be full, I do not see any visible leakage. Why?
3.0 liter engine
Monday, December 22nd, 2008 AT 6:29 PM
ZACKMAN
MECHANIC
Check your engine oil to see if it has "milky" substance. How about your antifreeze in the radiator. Do you see any evidence of oil in it? Perform compression and leak down test to verify that the head gaskets are not leaking.
SPONSORED LINKS
Wednesday, December 24th, 2008 AT 1:23 AM
MEINDERS
MEMBER
I do not see any issue with oil in the antifreeze, or, and no milky color in the oil.
Thursday, December 25th, 2008 AT 12:08 PM
ZACKMAN
MECHANIC
Then, perform compression and leak down test to verify that the head gaskets are not leaking.
