1998 Plymouth Voyager Car wo't shift into 3rd gear
1998 PLYMOUTH VOYAGER
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
PACHO
The car won't shift into 3rd gear and somebody told me the problem is the speed sensor but I have not been able to find the speed sensor, could you please tell me if the speed sensor makes sense, and if it does, where is it located?
Thanks
Jan 1, 2010 at 1:35 PM
  • 110,194 POSTS
Actually, I doubt the speed sensor is causing the problem. It could but it will usually set the check engine light. Here is a picture of the VSS:
https://images.2carpros.com/forum/automotive_pictures/249084_VSSS_1.jpg
Let me know if it helps. Joe
Jan 4, 2010 at 2:30 PM
