1998 Plymouth Voyager booging uphill
1998 PLYMOUTH VOYAGER
MYRIAS
Engine Performance problem
1998 Plymouth Voyager 6 cyl All Wheel Drive Automatic
i recently bought a plymouth voyager 1998 when going up hill it starts to bog out almost like it will shut down. It will only go 20 miles per hour up hill.
Aug 5, 2010 at 12:01 PM
SERVICE WRITER
  • 9,123 POSTS
I would first lean toward a fuel pressure problem.
Put a fuel pressure gauge on it and run it to the windsheild to monitor it. See if the pressure falls out of spec while the problem occurs.
Aug 5, 2010 at 12:54 PM
MYRIAS
thank you for the help. i do appreciate it. I will def. do that.
Aug 5, 2010 at 4:56 PM
