How can you change a blinker light without going through the wheel wall? I have problems seeing it and the wiring is in the way.
Feb 4, 2010 at 2:56 AM
CH112063
✓Experienced Mechanic
The front you must lay on your back to get to. The rear should have a lens that unscrews. This will remove the whole unit making it serviceable.
The front has a plug you must turn to remove. 45 degrees. I know it's a pain.
Feb 4, 2010 at 1:45 PM
