there should be a routing diagram on a decal in the engine compartment. Get it lined up best you can on all pulleys except the nearest one to the tensioner, probably the alternator, then use a large wrench on the tensioner to pull it back and with your other hand slip the belt over the remaining pulley.
Jun 21, 2009 at 2:48 PM
