airbag light issue
1998 PLYMOUTH VOYAGER
18,000 MILES • 6 CYL • FWD • AUTOMATIC
ALGOO
MY AIRBAG LIGHT IS ON IN MY DASHBOARD, I WOULD TO KNOW THE PROBLEM AND IF IT IS THE CLOCKSPRING WHERE IT IS SITUATE IN MY VEHICLE.
ALSO WHEN DRIVING MY TRANSMISSION REVS AT 4000 RPM WHEN I REACH 40 MPH WHAT IS THE POSSIBLE CAUSE AND HOW CAN I FIX IT.
Oct 14, 2010 at 1:33 PM
  • 31,937 POSTS
Hi there,
To help narrow down both problems, i would start with a scan as this will identify the SRS fault and possibly the trans fault as well, any SRS work should be carried out by a qualified tech as serious injury can result if not handled correctly.
mark (mhpautos)
Oct 14, 2010 at 1:44 PM
THIS IS MIKE
  • 686 POSTS
Replied on October 14, 2010
Clock spring is the most common failure
it was such a bad design Chrysler had to extend the warranty 100K
Need to have it checked for codes
Answered by BMRFIXIT (expert)
19,736 answers provided
Jun 5, 2013 at 7:49 AM
THIS IS MIKE
  • 686 POSTS
Replied on October 15, 2010
will need to have the restraint system scanned to retrieve the trouble code(s) that are stored since the airbag light is on. as for the tranny issue, there may be a sensor or solenoid not working properly preventing tranny from shifting.
Answered by bluelightnin6 (expert)
17,236 answers provided
Jun 5, 2013 at 7:50 AM
