1998 Plymouth Voyager A/C Clutch will not engage
74,000 MILES • 6 CYL • 2WD • AUTOMATIC
PD107Q
My 98 Plymouth Gran Voyager A/C clutch will not engage. The system has adequate refergerant. Trouble shooting has revealed that the A/C clutch relay solenoid does not have a ground. The Plymouth service manual states that the PCM operates the clutch relay ground circuit. I am assuming that i need to replace the PCM, but before I buy one I would like to have a second opinion that it is the PCM.
Thanks,
James Gorman
May 29, 2010 at 6:30 AM
  • 75,988 POSTS
When the PCM grounds the coil side of the AC clutch relay it powers the magnetic clutch to engage the compressor
https://images.2carpros.com/forum/automotive_pictures/12900_ac_relay_clutch_1.jpg
May 29, 2010 at 11:49 AM
