1998 Plymouth Voyager
COREY JENKINS
  • 1998 PLYMOUTH VOYAGER
  • 6 CYL
  • 160,000 MILES
My speedometer, mileage, gas locator, and engine heat reader will not move, its like it froze, do I need to replace a fuse or something?
Friday, May 8th, 2009 AT 9:07 AM
BMRFIXIT
  • 19,053 POSTS
Checking fuses should be 1st step
if all OK
suspect bad cluster
remove and check the welds on the back
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Sunday, May 10th, 2009 AT 6:17 AM
