HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Plymouth
Voyager
Climate Control
Blower Fan
Speed
SPONSORED LINKS
1998 Plymouth Voyager
WCGRAY
MEMBER
1998 PLYMOUTH VOYAGER
6 CYL
FWD
AUTOMATIC
125,000 MILES
Heater A/c Blower only runs on high speed.
is the switch bac?
Friday, September 5th, 2008 AT 7:20 PM
OBXAUTOMEDIC
MECHANIC
Sounds like the Blower Motor Resistor.
It is located on the right rear of engine compartment on fire wall.
SPONSORED LINKS
Friday, September 5th, 2008 AT 8:53 PM
BLACKOP555
MECHANIC
Nope! Sounds like your problem is a bad blower motor resistor block.
What happens its the resitor fails and the low speeds work, but highspeed which is un resisted bypasses it and works.
Friday, September 5th, 2008 AT 8:54 PM
Please
login
or
register
to post a reply.
Related Blower Fan Speed Content
1999 Plymouth Voyager Heater Blower
I Have A 1999 Plymouth Voyger That The Heater Blower Only Works On High The Other Setting Very Little Air Comes Out Is The Blower Bad Or...
Asked by
emtlbt
1 ANSWER
1999
PLYMOUTH VOYAGER
1998 Plymouth Voyager Fan Blower Doesn't Work Right
Heater Problem 1998 Plymouth Voyager The Blower Motor Is Not Working Properly. It Was Only Working On The High Speed, So I Changed...
Asked by
mayflower6
1 ANSWER
1998
PLYMOUTH VOYAGER
Power Door Locks And Heater Blower Not Working
First Noted As Turn Signal Failure, With Dash Airbag And Abs Lights On. This Was Intermittent. When The Airbag And Abs Lights Were Off...
Asked by
moet
6 IMAGES
2000
PLYMOUTH VOYAGER
1997 Plymouth Voyager When Ac Is On Fan Fuse 40a...
I Found That Ac Was Not Cooling And The Radiator Temperature Was Extremely High. On Checking Found That The Fan Fuse Was Blown Off. When...
Asked by
placid
1997
PLYMOUTH VOYAGER
1996 Plymouth Voyager Blower Not Working
Blower Is Only Working On High And Not Working On Low And Medium
Asked by
imrsidd
1 ANSWER
1996
PLYMOUTH VOYAGER
VIEW MORE
SPONSORED LINKS
How to Use a Test Light
How to Replace the A/C Blower Motor
How to Find Low Side A/C Service Port
Online car repair manuals
