1998 Plymouth Grand Voyager limp mode
1998 PLYMOUTH VOYAGER
C. J. MACK
My van is a 1998 Plymouth Grand Voyager with 118,000 miles. It has a 3.3L engine with an automatic 3 speed transmission. The problem does not create any strange smell or sound. I have a minor oil leak from the pan gasket - unrelated to current problem. The problem is as follows: in March of 2007 we had the transmission fluid changed (completely a maintenance item, no problem existed at the time). Two days later on a family trip while traveling on the highway we noticed the transmission go into limp mode (staying in second gear). Along with this was the "service engine soon" light. Have had the car looked at and no obvious cause and it appears that there are no mechanical problems. Recently within the last two months, this limp mode seems to be occuring more and more often. The limp mode condition is reset when the ignition is turned off and the car is restarted. Today, November 4th, had error codes read from computer and they are P0700 and P1776. I would like any suggestion on what could be causing the problem. I am considering 4 possibilities: 1. wrong trasmission fluid (at service they put in dextron plus additive), 2. one or both of the speed sensors, 3. transmission control module, 4. solenoid assembly. I am open to any and all considerations, thank you.
Nov 4, 2007 at 12:44 PM
ANGELINA1755
I had the same problem with my same year g.v. The problem was traced to a corroded wire- the part was two dollars or so, and the hourly rate was over three hundred dollars. However, it did solve the problem.
Jan 4, 2008 at 9:23 AM
OREGONTERRY
angelina1755 - please help!
I am having the exact same problem. What corroded wires?
I have replaced fluid, speed sensors and solenoid pack. This is driving me insane. Exact same error codes previously mentioned by CJ Mack, 1776 and 0700. vehicle is a 99 Grand Voyager, 135k miles, otherwise beautiful condition. Just ridiculous trying to figure this one out. Please help
Apr 13, 2012 at 3:54 AM
