1997 Plymouth Voyager wont start when hot
1997 PLYMOUTH VOYAGER
117,000 MILES • 6 CYL • FWD • AUTOMATIC
ARNELL
my car wont start when hot, my fans comes on some times but goes off. after waiting several hours it well start but shut down after i drive again so what should i do to solve this problem.
Jun 27, 2010 at 2:55 PM
BMRFIXIT
  • 19,053 POSTS
Does it crank but will not start ?
after it warms up does it stall on you and will not start but it will crank ,if so check for spark and suspect crank sensor
need to be checking for codes too
if no crank suspect starter ,and after it starter check charging system
Jun 27, 2010 at 10:56 PM
