1997 Plymouth Voyager Windshield-washer fluid pump
1997 PLYMOUTH VOYAGER
FINKLY
1997 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
I have ascertained that I need to replace the windshied-washer fluid pump on my Plymouth Voyager, howerer, I am having trouble accessing it. How do I get at the washer fliud pump on this car? (Wipers work and punp works in back but not in front.)
Dec 17, 2009 at 1:03 AM
  • 110,244 POSTS
The washer bottle needs removed to access the pump. To do this, raise and support the vehicle. Remove the right front splash shield. Disconnect electrical connectors for both front and rear pump. Place a pan under the resivour to catch the solvent and remove the rubber hoses from both pumps. Next, remove the bolts holding the tank in place. Replace the bad pump and reverse the order.
IF you run into trouble, let me know.
Jan 4, 2010 at 7:07 AM
