1997 Plymouth Voyager When AC is on Fan Fuse 40A blows
250,000 MILES • 6 CYL • 2WD • AUTOMATIC
PLACID
I found that AC was not cooling and the radiator temperature was extremely high. On checking found that the fan fuse was blown off. When the fuse was replaced the fans run and the AC cools. But soon the fuse blows off again.
Can anyone help find the problem
Aug 13, 2009 at 3:20 AM
MINIVAN1997
Have you tried using a larger fuse?
Aug 22, 2009 at 3:44 AM
DOCFIXIT
  • 18,828 POSTS
I s fuse #4 a 40 amp? if yes try unpluging one fan at at time see cif fuse holds .That is faulty fan.
Aug 22, 2009 at 3:56 AM
PLACID
I found that one of the fans is faulty. The magnets inside the motor fallen and stuck. Replaced the fan assembly.
Thanks for you response anyway.
Aug 22, 2009 at 12:52 PM
