1997 Plymouth Voyager Trouble code P0123
1997 PLYMOUTH VOYAGER
TROOPERCHIX
Engine Mechanical problem
1997 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
I am getting a P0123 trouble code, and the engine is intermittently feeling like it wants to seize or stop and the throttle sounds like it is wide open. I just had it back from the shop for a tune up. Any ideas?
Jan 19, 2010 at 4:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
P0123 Throttle Position Sensor Voltage Low
Suspect faulty TPS or wiring is bad to TPS
Jan 25, 2010 at 6:18 PM
