1997 Plymouth Voyager timing
1997 PLYMOUTH VOYAGER
BERGYSTN
Engine Mechanical problem
1997 Plymouth Voyager 4 cyl Front Wheel Drive Automatic
what cylinder is top center when the crank is in the rught position
Mar 8, 2009 at 12:15 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:bb6fa3f7c3="bergystn"]Engine Mechanical problem
what cylinder is top center when the crank is in the rught position[/quote:bb6fa3f7c3]
When setting the timing the #1 cylinder should be at TDC on the Compression Stroke.
Mar 8, 2009 at 12:25 AM
