1997 Plymouth Voyager smoke from the exhaust tail
1997 PLYMOUTH VOYAGER
TOMTOMMY2
1997 Plymouth Voyager Four Wheel Drive Automatic
in the begining there is white smoke coming from the exhaust pipe...and it stop after a while....and especially when iam on the reverse mode.....and after moving the smoke stop....but when i stop and press on the accelerator pad smoke come again(does the spark plugs do this as i think it should be replaced as the car is lightly shacking)
Sep 13, 2008 at 12:55 AM
2CARPRO JACK
  • 11,533 POSTS
White smoke is usually coolant/anti-freeze. If it is missing as well you may have a blown head gasket. Have the cooling system chemical tested for exhaust gasses.
Sep 13, 2008 at 1:06 AM
