1997 Plymouth Voyager replacement of brake tubing
165,000 MILES • 6 CYL • FWD • AUTOMATIC
RPM126
i have difficulty stopping and have found brake fluid leaking from the lines located above the gas tank. Do I have to drop the tank in order to replace these brake lines?
Aug 29, 2009 at 12:09 PM
  • 31,937 POSTS
Hi there,
thank you for the donation,
I would be best to remove the tank as i feel that there will be brake line mounting points you will need access to, for the extra time taken to drop the tank, i am sure that it will make this job so much easier.
mark (mhpautos)
Aug 29, 2009 at 12:51 PM
