1997 Plymouth Voyager LOCATION COOLING RELAY
189,000 MILES • 6 CYL • 2WD • AUTOMATIC
PETE999
LOCATION OF COOLING FAN RELAY
Jun 9, 2009 at 3:58 AM
PBLECHAR
  • 6 POSTS
It is a solid state module with three wires in a harness.
It is on the left frame rail way under the general area of the battery. Look for it from underneath the car and you can reach it from there. It would be wise to use silicon heat sink compound before bedding the new one. They run about $80.
Paul B. in Boston
Jun 9, 2009 at 4:24 AM
PBLECHAR
  • 6 POSTS
Found a photo on this board that will show you what I was trying to describe in words.
Good Luck.
Paul in Boston
Jun 9, 2009 at 5:03 AM
