1997 Plymouth Voyager LOCATION COOLING RELAY
PETE999
  • 1997 PLYMOUTH VOYAGER
  • 6 CYL
  • 189,000 MILES
LOCATION OF COOLING FAN RELAY
Tuesday, June 9th, 2009 AT 10:58 AM
PBLECHAR
  • 6 POSTS
It is a solid state module with three wires in a harness.
It is on the left frame rail way under the general area of the battery. Look for it from underneath the car and you can reach it from there. It would be wise to use silicon heat sink compound before bedding the new one. They run about $80.
Paul B. In Boston
Tuesday, June 9th, 2009 AT 11:24 AM
PBLECHAR
  • 6 POSTS
Found a photo on this board that will show you what I was trying to describe in words.
Good Luck.
Paul in Boston
Tuesday, June 9th, 2009 AT 12:03 PM
