1997 Plymouth Voyager LEAKY POWER STEERING
1997 PLYMOUTH VOYAGER
400,000 MILES • 6 CYL • 2WD • AUTOMATIC
ARVIND
HOW TO FIX LEAKAGE OF POWER STEERING FLUID
May 7, 2008 at 5:27 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:6e9e95bf98="Arvind"]Steering problem
1997 Plymouth Voyager 6 cyl Two Wheel Drive Automatic 400000 miles
HOW TO FIX LEAKAGE OF POWER STEERING FLUID[/quote:6e9e95bf98]
First off were does it look like it is leaking? If it is a hose replace it. In some cases all that is needed is to replace the O-Rings on the Hoses if it is leaking at the pump connection or at the steer rack connection.
May 9, 2008 at 9:50 AM
