1997 Plymouth Voyager Instrument panel quits
180,000 MILES • 6 CYL • FWD • AUTOMATIC
TRGRIDER
The instrument panel and speedometer and tach and fuel gauge will quit working when driving. Sometimes you can hit the dash to the right of the steering wheel and it comes back on.
Dec 27, 2009 at 8:55 AM
MATHIASO
  • 1,209 POSTS
hello trgrider The instrument panel wiring harness connector is located at the bottom of the body control module. It's exactly the side where you hit when it's not working. Check if the connector to the module is tight (check all of them) the instrument panel is one of them.
https://images.2carpros.com/forum/automotive_pictures/46384_stabilizer_2.jpg
Dec 27, 2009 at 10:27 AM
