1997 Plymouth Voyager Instrument illumination
RWHEEL
Electrical problem
1997 Plymouth Voyager All Wheel Drive Automatic 178000 miles
My instrument cluster back lighting does not work. I have performed all the tests that I can without a code reader per a Mitchell's guide. All my test point to a failed body control module. Can I purchase a matching BCM from a wrecking yard and install it without having other problems with the ECM or other modules? Thanks
Jun 18, 2008 at 3:55 PM
BMRFIXIT
  • 19,053 POSTS
BCM need to be programmed to the vehicle
or it will not start and run
Have an automotive repair question!
Sign up and ask your automotive question !
https://www.2carpros.com/affiliate/uid/bmrfixit_1_tlid_1
Jun 19, 2008 at 4:58 AM
