1997 Plymouth Voyager HELP!!!!
249,812 MILES • 6 CYL • 4WD • AUTOMATIC
FIREEYEZ
Hi I am having which I think Is my body moduler problems. I have been having the security going off so I figured how to stop that by locking door and unlocking so it stops that and service engiine light I disconnected the battery for 10 min and hooked it up now the service engine light is off for now. I have van parked cause I don't know if it is safe to drive it when I still have the airconditioner and defroster back windsheild light still blinking.. Is safe to drive van or not and how do I reset the body modular so lights don't blink? Or do I have to by new one this has been going on for 5 months now.Thank you Hope I can get some help miss my Van...Vicky
Jan 14, 2008 at 7:46 AM
BMRFIXIT
  • 19,053 POSTS
[quote:18451d50b9="fireeyez"]Other Category problem
1997 Plymouth Voyager 6 cyl Four Wheel Drive Automatic 249812 miles
Hi I am having which I think Is my body moduler problems. I have been having the security going off so I figured how to stop that by locking door and unlocking so it stops that and service engiine light I disconnected the battery for 10 min and hooked it up now the service engine light is off for now. I have van parked cause I don't know if it is safe to drive it when I still have the airconditioner and defroster back windsheild light still blinking.. Is safe to drive van or not and how do I reset the body modular so lights don't blink? Or do I have to by new one this has been going on for 5 months now.Thank you Hope I can get some help miss my Van...Vicky[/quote:18451d50b9]
as for check engine light you need to get the codes so it pin point the problem area
if you don’t have a code reader you can cycle key on off three times ending with key on
read code s in odometer reading area P0000
for the blinking defrost and rear wiper
is your AC working
if so its not cold enough or the system need to be calibrate
you can drive van no problem if the lights flashing
let me know
Jan 16, 2008 at 12:43 PM
