1997 Plymouth Voyager Heater/defrost fan
1997 PLYMOUTH VOYAGER
DOODLEBOY
Heater problem
1997 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
Incab heater/defrost fan doesn,t allways work. sometimes comes on then quits, sometimes doesn,t come on at all. Would like a list of possible causes, and how to fix myself. Unable to take to garage due to cost's involved.
Oct 31, 2009 at 6:33 AM
BMRFIXIT
  • 19,053 POSTS
Locate blower motor and disconnect wiring check for power and check for ground
if have the two and motor not working then you need a blower motor
if have no power check relay and wiring and ignition switch
if no ground check wiring and resister
Nov 1, 2009 at 10:18 PM
