Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Plymouth
Voyager
Ignition
Coil
Replace/Remove
1997 Plymouth Voyager HAVE NO FIRE IN THE WIRES
1997 PLYMOUTH VOYAGER
18,900 MILES • 6 CYL • FWD • AUTOMATIC
SHARON1997
MEMBER
1 POST
i STAT THE VAN IT DOSENT HAVE FIRE i HAVE ALREADY INSTALL A COIL AND NEW WIRE AND RODOR AND CAP
Nov 16, 2008 at 1:25 PM
BMRFIXIT
Experienced Mechanic
Check if the rotor spin as engine cranking
check timing belt
check fuses and relay
check and suspect crank sensor
Nov 17, 2008 at 10:16 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
