1997 Plymouth Voyager gas is leaking from tank under van
1997 PLYMOUTH VOYAGER
108,200 MILES • 6 CYL • 2WD • AUTOMATIC
HAYNGURL68
hi there is gas leaking from the tank under the van I can see a hole in the tank my question is how do I fix it and what would the estimate be to fix it? thanks broke and unemployed
Oct 10, 2009 at 8:33 AM
It can be done without dropping the tank temporary Check NAPA for a gas tank repair kit-till you can have it welded or replace.
Oct 10, 2009 at 9:05 AM
