1997 Plymouth Voyager fuel pump switch
1997 PLYMOUTH VOYAGER
CAMRYQ
my van isnt starting and someone told me that i might have to flip the fuel pump switch i did run out of gas but tere is gas in it now are they right? and where is it located so i can fix it? thank you!
May 15, 2008 at 12:13 AM
There's no such thing for your van-unless its a FORD product. But you can try below to find out if its a fuel or ignition system problem.
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
May 15, 2008 at 12:23 AM
