1997 Plymouth Voyager CPS Sensor keeps dying
1997 PLYMOUTH VOYAGER
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
IBMCORP
I have a 97 plymouth voyager with the 3.0L engine and 3 speed transmission.
A few days ago I decided to wash out the engine area at the car wash (I've done this dozens of times before). About 15 minutes later, I made it home and left the car running in the driveway as I was going to leave somewhere again. Well, it stalled. I tried to turn it on and it wouldn't turn on.
I did do some checks as I am a pretty good hobby mechanic and found it had no spark.
I thought I would change the crankshaft position sensor first, which did fix the problem. However, about 20 minutes later it stalled again....
I changed the CPS 4 times now and it won't run for more than 5-20 minutes before I need to replace the CPS again.
I did try changing the computer & then the CPS but the same thing happened.
I tried to wait a few days and then try again but that didn't help either. I did change the CPS as part of a tune up I did a year ago.
What would cause the CPS to short out so much? It's been atleast a week now that that I washed out the engine and would think all the water would have dried up.
Could there be a different problem, and changing the CPS is just partially helping it?
Any advice would be great!
Jul 11, 2009 at 11:27 AM
BMRFIXIT
  • 19,053 POSTS
Check in the fuse and relay box
looking for an ASD relay
mark it and switch around with a similar one
give it a try
also check and suspect the coil if the relay check out OK
Jul 11, 2009 at 2:17 PM
IBMCORP
I replaced the ASD relay & CPS today. The van ran for about 4-5 minutes and died again. I am not getting a spark just as before.
Any other ideas?
Thanks
Jul 13, 2009 at 2:18 AM
