1997 Plymouth Voyager coolant temperature sensor
MOVIC11
Engine Cooling problem
1997 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
where is the location of my coolant temperature sensor?
Jun 6, 2010 at 5:00 AM
  • 55,561 POSTS
The engine Engine Coolant Temperature Sensor is under the ignition coil.
https://images.2carpros.com/forum/automotive_pictures/12900_cts_44.jpg
Please let me know if you need anything else to get the problem fixed. Best, Ken
Mar 17, 2017 at 5:59 AM
CARCURIOUS
1998 Plymouth Voyager 6 cyl Front Wheel Drive Automatic 113005 miles
Can not find where to replace coolant sensor....
Car has been over heating....we've replaced the thermostat,the relay switch and fuse...and fans will not come on.....we were told it's probably needs anew coolant sensor....where is it located?
Mar 17, 2017 at 6:00 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
depends on engine size, list is below..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_793.jpg
