1997 Plymouth Voyager Check engine lite fault code 355
JDLCONE
  • 1997 PLYMOUTH VOYAGER
Electrical problem
1997 Plymouth Voyager V6 Two Wheel Drive Automatic 157564 miles
Have changed plugs, wires, coil, continue to get "misfire" problem and won't pass inspection! What do or can I do, love this van.
Thursday, December 6th, 2007 AT 4:58 PM
BMRFIXIT
  • 19,053 POSTS
Not every misfire is related to spark plugs or the ignition system
Check if you have vacuum leak effecting said cylinder
Do a compression check
Check fuel injectors
and whats the codes
good luck
Thursday, December 6th, 2007 AT 5:35 PM
