1997 Plymouth Voyager 97 plymouth grand voyager se 3.0 6 cy
1997 PLYMOUTH VOYAGER
13,000 MILES • 6 CYL • FWD • AUTOMATIC
LEANNA_ALEXANDRIA2010
hi i have a 97 plymouth voyager and it has a few problems. i was driving and all of a sudden it started to shake really bad well it overheated so i turned it off and let cool down and drove 2 mins till i got home it was putting a lot of thick white smoke i again shut the engine off and for at least 5 mins of being turned off it was still smoking. had headgasket replaced still same problem.problem 2 the power windows,locks,inside lights, headlight all quit working unless the key is on of engine started can some one please help me.
Jun 15, 2010 at 11:54 AM
BMRFIXIT
  • 19,053 POSTS
Same problem ??
Overheating or white smoke
if it not overheating and just white smoke may have to run it for few to burn all coolant that is in the exhaust system
if its overheating and white smoke will not go away
I would suspect that the heads is at fault if the gasket was replace but the heads were not checked and resurfaced
Jun 15, 2010 at 10:53 PM
