1997 Plymouth Voyager
JEREMY MOORMAN
  • 1997 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 191,000 MILES
I have a '97 voyager that just quit while idling in my driveway. I've replaced the fuel pump, fuel relay, auto shutdown relay, crank sensor, dist. Cap and rotor, and pcm unit. I've also checked the timing covers to see if belt is frayed, no luck. To me it seems electrical but I'm not sure where to go next. Any suggestions?
Monday, July 14th, 2008 AT 5:28 PM
MERLIN2021
  • 17,250 POSTS
Is your check engine light on? If yes turn the key from off to on three times, on the fourth one leave it in the on position, the codes will display on the odometer, write em down and post em...
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
and this one!
Monday, July 14th, 2008 AT 5:52 PM
