1997 Plymouth Voyager
FINKLY
  • 1997 PLYMOUTH VOYAGER
1997 Plymouth Voyager 6 cyl Front Wheel Drive
My back windshield-washer fluid pump works while my front does not. I want to know if they are both on the same fuse, but if not, how do I locate which fuse to change? If it is not the fuse, do you know what else it could be?
Thursday, December 17th, 2009 AT 8:11 AM
  • 109,885 POSTS
THey are on the same circuit. If it doesn't work, either there is a bad connection or washer motor. To check it, raise and support the vehicle. Next, remove the right front wheel and the inner splash guard (inner fender). Now you will see the washer resivour. Check the pump for the front to make sure it is tight and not corroded. IF it looks good, use a test light to see if you are getting power to it. IF there is power, remove the resivour and replace the pump.
LEt me know if you have other questions.
Monday, January 4th, 2010 AT 3:16 PM
