1996 Plymouth Voyager van not geeting any spark
176,000 MILES • 6 CYL • FWD • AUTOMATIC
ALLENSCHEEL
  • 11 POSTS
I have a 1996 plymouth voyager the car was stalling and then wont start the codes said coil i replaced the coil ran ok then same issue the code said cam sensor so i replaced that still wasnt getting any spark so i called auto parts store and they said crank sensor so i went and put that in and still nothing any thoughts
Sep 23, 2010 at 6:35 AM
  • 75,988 POSTS
Check the ignition control module
Sep 23, 2010 at 9:23 AM
ALLENSCHEEL
  • 11 POSTS
where would the ignition control moduel be located also could it also be a powertrain control moduel or a fuse under dash board called ignition feeder please give your opionion
Sep 23, 2010 at 1:15 PM
  • 75,988 POSTS
Check and test the ignition hall effect sensor in the distributor. BTW do you have power on the positive side of the coil?
Sep 23, 2010 at 1:35 PM
