1996 Plymouth Voyager Stalling
JJUICYM
  • 1996 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 189,201 MILES
My Van is stalling. This is what I have done. Gave it a tune up plugs cap and rotor, airfilter, replaced crank sensor. Used OBDII tool and no codes other than lost of battery supply in the last 40 cycles came up. Also have half lights on back of vechile not working have replaced all light bulbs still nothing. Van is still stalling after it has been driven a few miles. Do you have any other ideas?
Friday, July 25th, 2008 AT 5:50 PM
JJUICYM
Went to repair car in general and found to check the the ECM relay or better known as the Auto shut off relay and switch it out with new one. Took the van for an hour drive and had no problems
Friday, July 25th, 2008 AT 10:03 PM
