1996 plymouth voyager SE
1996 PLYMOUTH VOYAGER
JOESU
  • 5 POSTS
i have replaced the fuel rail, filter, pump, plugs, coil, wires, fuel injectors, PCM. However, the engine still hestitates when accelerating from idle and going up a hill. The service engine light blinks about 5 times then stops. When driving along at about 30-50 mph the van runs just fine. Also, after stopping when running at 50-60 mph sometimes it will run rough as a cob when idling at stoplight. It does not audibly backfire but the codes have indicated misfiring on the same two cylinders [1 & 5].
Apr 25, 2007 at 7:09 AM
MARKM
Seeing that it is always cylinders 1 and 5, I highly suspect that you need a new distributer cap. Remove the cap and visually inspect it for cracks and/or carbon trails from arcing. good luck
Apr 25, 2007 at 2:21 PM
JOESU
  • 5 POSTS
[quote:05f0f7ebc6="MarkM"]Seeing that it is always cylinders 1 and 5, I highly suspect that you need a new distributer cap. Remove the cap and visually inspect it for cracks and/or carbon trails from arcing. good luck[/quote:05f0f7ebc6]
Would that not have been replaced with the coil, wires and plugs routine?
Apr 25, 2007 at 2:48 PM
