1996 Plymouth Voyager replaced all braking sytem
1996 PLYMOUTH VOYAGER
PEDAL
Brakes problem
1996 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
Replaced the all the braking system yesterday and the drivers side i was smoking and maybe froze up not sure. Am checking the lines to make sure no pin holes and that they are on tight. What would be causing this problem ?
May 16, 2009 at 3:31 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:65ac577d5d="pedal"]Brakes problem
Replaced the all the braking system yesterday and the drivers side i was smoking and maybe froze up not sure. Am checking the lines to make sure no pin holes and that they are on tight. What would be causing this problem ?[/quote:65ac577d5d]
First thing to do is to jack up the front of the vehicle. Spin problem wheel if won't spin, open bleeder on caliper and try spinning again if it spins replace brake hose. If does not spin then most likely caliper is locked up.
May 16, 2009 at 4:36 AM
