1996 Plymouth Voyager Please help me I have already been to
AMY43084
  • 1996 PLYMOUTH VOYAGER
  • V8
  • FWD
  • 137,000 MILES
My van keeps dieing then I put it into reverse or drive. I have been getting past this by warming the van up then giving gas as I put it in gear(as I was told to do by the last mechanics since they could not find the problem). Now it is vibrating and jerking and when I slow down it wants to die. Any ideas on what could be wronge?
Tuesday, May 11th, 2010 AT 11:09 AM
BMRFIXIT
  • 19,053 POSTS
Do you have a check engine light on
have to have it checked for codes
open hood and check for vacuum leaks
check timing?
Check IAC valve
Thursday, May 20th, 2010 AT 6:06 AM
AMY43084
Engine light was not on until the mechanic checked the codes. He said everything came back good, and then cleared the engine light. The van has been checked for vacume leaks also and there was none.
Friday, May 21st, 2010 AT 11:45 AM
BMRFIXIT
  • 19,053 POSTS
What do you have an engine size?
Was the crank sensor checked?
Friday, May 21st, 2010 AT 1:02 PM
