1996 Plymouth Voyager Parking Brake system
JTHOMPSON3171
Brakes problem
1996 Plymouth Voyager 4 cyl Two Wheel Drive Automatic
On My 1996 Plymouth Voyager, my husband has replace the whole parking brake cable system, We can not get the cable to stay on the pedal. He attaches the cable to the pedal, the cable comes off when the pedal is depressed. He slides the cable in to the hole in the pully and squeezes the tab so that the cable is pinched in, and then he hooks it up to the rest of the system. The rest of the system is fine, just that the cable is coming off the pedal are we doing something wrong or missing something. Thank you
Apr 7, 2008 at 11:23 AM
D5NUKE
  • 61 POSTS
Ensure you route the cable the correct way and set the tension on the cable.really the only reason it would come out of the pulley is if it is routed wrong and its being pulled out when depressed.Do you feel tension on the pedal when pushed if to much tension the it needs ajusted.To little and the cable will be sloppy.Hope this helps
Apr 7, 2008 at 12:32 PM
