1996 Plymouth Voyager NOT GETTING GAS
CRYSTAL200132
1996 Plymouth Voyager 6 cyl Automatic
my cars is not getting gas, i replace the fuel pump and also the fuel pump relay and its still not getting gas. yes there is gas in it. so what is the next thing i need to check/do to get my car back on the road.
Dec 7, 2009 at 12:23 PM
  • 16 POSTS
I would check the fuel filter it could be clogged and need replacement. It would be a cheaper fix. Also check the auto shutdown relay, in the relay fuse center under the hood. Let me know if this helps. Good luck.
Robert (1968)
Dec 12, 2009 at 3:13 AM
