1996 Plymouth Voyager no fuel dilevery
1996 PLYMOUTH VOYAGER
220,000 MILES • 6 CYL • FWD • AUTOMATIC
MAJIDZAH
hi guys
my engin cut out wile I was driving the fuel relay switch dos not clik and the fuse is ok so I used a bit of easy-start it started for a second and made a taping sound then I realised that there are two shtdown relays on either side of the fuel pump relay can you please tel me what (EATX shutdown relay) and (AOUTO SHUTDOWN relay is for and advise me on what to do. Thank you guys.
majid...
Oct 22, 2009 at 11:27 AM
Check fuse PTC1 9amp and fuse no.13 20amp and get back with me. BTW all you got is one ASD relay
Oct 22, 2009 at 11:57 AM
BMRFIXIT
  • 19,053 POSTS
EXAT is a tranny relay will not effect the starting of the engine
Auto shut down on the other hand will make the engine stalls off
if you suspect relay mark it and switch it with a similar
take it for a run
let me ask you few question s
when it stalls on you does it start back up, right away or you have to wait few min
did you check for spark
if you loose spark too suspect crank sensor
if relay was not found to be at fault
if you have spark and no fuel I would suspect fuel pump module inside fuel tank
Oct 22, 2009 at 12:03 PM
MAJIDZAH
The no.13 20 amp is ok, but where is the PTC1 9 amp?
I do have a constant spark. The engine stalled, and has not started since.
If possible could I please have some diagrams/pictures??
Also, what does the ASD do? What triggers it?
Oct 22, 2009 at 12:53 PM
The PTC1 fuse 9amp is in the junction block left side of instrument panel. Be advised the Auto shutdown reelay has nothing to do with the fuel pump circuit.
Turn key On and at the fuel pump relay receptacle check for power on the white and black wire -Do you have it?
Oct 22, 2009 at 12:56 PM
BMRFIXIT
  • 19,053 POSTS
do you have fuel pressure
suspect bad fuel pump
located in fuel tank
try and listen when 1st key on can you hear the fuel pump
MAJIDZAH
I tried locating the PTC1 fuse I found a fuse block on top left hand side of the drivers foot-well and none of them are marked as PCT1 can you please let me know how to find it
Oct 22, 2009 at 1:47 PM
See below
https://images.2carpros.com/forum/automotive_pictures/12900_ptc1_1.jpg
Oct 22, 2009 at 1:54 PM
