1996 Plymouth Voyager leak
1996 PLYMOUTH VOYAGER
132,000 MILES • 6 CYL • FWD • AUTOMATIC
DANNY91194
I have a 1996 grand voyager that does not hold 134a freon. I put the freon in it with the leak dye. I see the dye coming out of the drian that the water comes out of when the a/c is running? Where does the water come from? Is it under the dash ? Is this a common problem with these vans?
Jul 12, 2008 at 5:40 AM
JALOPYPAPA
  • 467 POSTS
THe evaporator is leaking. Yes, this is a common problem, and yes, it is inside the dash, and yes, it is expensive to fix. I'm sorry.
Jul 15, 2008 at 5:08 AM
