1996 Plymouth Voyager i need help bad
RACHELELIZABETH1990
Shakes or Wobbles problem
1996 Plymouth Voyager Two Wheel Drive Automatic 178951 miles
ok my van got wrecked on the drivers side which bent my gas tanka little (its a little complicated to put gas) well after i wrecked it the gas cap wouldnt go on so i drove it with a rag in it till i fixed it. in the process of waiting it rained one night which water got in my tank not thinking about it i still drove it. well one night i was driving and it got jumpy and my engine knocked about 8 times and just died.. when i got it to cool down just a litle it would start for a few seconds and knock again so i talked to a friend he suggested getting "Heet / 12 oz. ISO gas dryer and antifreeze " and so i did and it didnt do much so i replaces the fuel injector line,oxygen sensor, and upgraded the gas to primium. that happened about 3 months ago and yesterday it happened again it just started puttering and knocking and turned off. so i added a gas cleaner and let it cool down and it started after a hour and has ran since today mid day it knocked turned off and i let it sit and it turned back on. but i noticed when it starts to knock i put it in nutural and reved up the engine and it wanted to pop something out the muffler like it is clogged somewhere but i dont nkow where i checked the water its fine the oil is good what do i look for now
May 24, 2010 at 4:44 PM
  • 31,937 POSTS
Hi there,
I would first change the fuel filter and i would cut open the old one and check to see how much muck is in it, start here.
mark (mhpautos)
May 24, 2010 at 5:59 PM
RACHELELIZABETH1990
it was changed when i changed the fuel line and oxegyn sensor
May 24, 2010 at 6:01 PM
  • 31,937 POSTS
I am thinking that you still have a tank with water and muck in the bottom and as it gets stirred up it has slowly been clogging the new filter.
mark
May 24, 2010 at 6:19 PM
RACHELELIZABETH1990
ok what should i do
May 24, 2010 at 6:21 PM
  • 31,937 POSTS
Just do a filter change and cut open the old filter, we know it has been only on a short time so it should be quite clean, if it is really dirty and blocked, we will know that the problem will be contaminated fuel.
mark
May 24, 2010 at 6:35 PM
