1996 Plymouth Voyager help me fiqure this out
1996 PLYMOUTH VOYAGER
145,000 MILES • 4 CYL • 2WD • AUTOMATIC
JR MECHANIC
my voyager the transmission well when its cold it dont move(it has transmission fluid in it) but if i let it warm up and then rev the engine then it will move in reverse and drive,Any thought or facts to help me out?
Dec 25, 2008 at 3:12 AM
BUDDYCRAIGG
  • 2,262 POSTS
you need to take it to a tranny shop.
there are lots of things that could be the problem.
the flute valves are not moving in the valve body, but once the valve body heats up it expands enough for the valve to slide.
an electrical solenoid somewhere is not working when it's cold.
some seal is allowing fluid pressure to bleed off until everything is hot and swelled up.
good luck
Dec 25, 2008 at 2:19 PM
