1996 Plymouth Voyager Heater fan stopped blowing
HERBO
Heater problem
1996 Plymouth Voyager 6 cyl Front Wheel Drive 204356 miles
started my van as usual to go to work fan switch was off, turned on nothing happened,(had worked the day before with no prblem). I've got no power to fan motor,fuse ok, poss. bcm? where would this be located?, resistor bad? Thanks for your consideration.
Mar 6, 2010 at 9:28 AM
  • 75,988 POSTS
Your probable causes here could be the blower switch, blower relay,blower motor resistor and blower motor itself-to rule out the blower motor direct power to it from the battery and go from there.
Mar 6, 2010 at 8:11 PM
HERBO
I' got power at the fuse,no power at the switch or fan, I don't where the fan relay is located, or the fan resistor. any help would be appreciated
Mar 8, 2010 at 2:32 AM
  • 75,988 POSTS
Check fuse no.3 40amp in the PDC, the resistor is at the right rear of engine compartment and the relay is at left side of dash behind junction block-Sorry no pic available
Mar 8, 2010 at 7:33 AM
