Heater problem
1996 Plymouth Voyager 6 cyl Front Wheel Drive 204356 miles
started my van as usual to go to work fan switch was off, turned on nothing happened,(had worked the day before with no prblem). I've got no power to fan motor,fuse ok, poss. bcm? where would this be located?, resistor bad? Thanks for your consideration.
Mar 6, 2010 at 9:28 AM
