1996 Plymouth Voyager fuel injector circuit
1996 PLYMOUTH VOYAGER
140,000 MILES • 6 CYL • FWD • AUTOMATIC
ALIASS
I would just like to ask if the fuel injector and the circuit are one in the same? service engine light is on, the message from the computer reader is; cyl. 2 fuel injector circuit malfunction. Does the whole injector have to be replaced, or are there faulty wires,(perhaps an exposed wire that would be shorting out)? You can feel it going in and out by way of engine power. sometimes it does work. Any response would be most appreciated. Thank you so much for your time!
Mar 19, 2008 at 2:25 AM
LEGITIMATE007
  • 5,121 POSTS
well I would check the wires to that injector to make sure they haven't been "eaten" through in some way and grounding out on something. if thats not the case then yes you will more than likely have to replace the entire injector
Mar 28, 2008 at 12:56 AM
