1996 Plymouth Voyager engine wont fold.
DONMECCA
  • 1996 PLYMOUTH VOYAGER
  • 6 CYL
  • 269,300 MILES
While driving one morning my car just died. No power, nothing.I had to get towed back home because I thought it was just a battery problem, so after getting another (battery that is)i turned the key and I got power to everything but it didnt turn over. All I got was a loud clinking noise from the starter, no crank just a clink everytime I turn the key so I had the starter checked out and AD. AUTO. PRTS said it was fine. Relays replaced were no help either can we get some help over here. Thanks in advance.
Tuesday, January 8th, 2008 AT 6:55 PM
  • 31,937 POSTS
Hi there, remove spark plugs & see if motor will turn by hand, If it is, and starter solinoid is engaging, check main power supply to starter, if ok and the engine turned by hand, re check starter of viability.
Mark (mhpautos)
Tuesday, January 8th, 2008 AT 7:53 PM
